Griots Pneumatic oil/liquid extractor
V10 MOJO
Youngstown, Ohio
saw this device in griots catalog. pretty cool. is it safe? anyone ever use something like this? i just did oil and psf yesterday and this wouldve saved a bit of time and mess.
ruckdr
Renton, WA USA
If it is from Griot's, it is good and will work. I would be curious if it removes all the oil. Griot's is just down the road from me, and I go there to pick up various products (no shipping-you know).
You must still get under the car and remove the oil filter, and fight that. If you use a pick, and/or a screwdriver and pock a hole in the oil filter in a place where it will drain straight down, then remove, the mess is greatly reduced.
Later,
jcaspar1
Sacramento, CA
The only messy part is the oil filter. No mess with the drainplug. I don't see how this would help much....
Warren 00 GTS
Lees Summit, MO, USA
I own this device. I use it primarily to change the oil in my motorcycles, and it does a great job. Doesn't work in the Viper, only will get about 3 quarts.
