GTS Hood Assembly
WSAYERS80
Orlando, FL.
Does anyone have a GTS hood assembly.they want to sell? Also my electric fan isn't switching on. Car quickly hit 240 close to 250.. What miightvthe issue be? Maybe fuse or relay?
90% done with my rebuild but I am interested in taking it to a mechanic/dodge to have them look it over and kinda run through it makesure I didn't miss something major. What do you guys recommend?
W
WSAYERS80
Orlando, FL.
Why would the overflow bottle or cap prevent my fan from switching on?. Fan operates of of a heat sensor and water temp.
W
WSAYERS80
Orlando, FL.
im thinking water pump
No because hot boiling water is circulating through. Hoses are hot to the touch and water boils over when cap is removed from reservoir. Which of coarse means water is properly circulating through the system. Thermostat is opening up and allowing water to pass through motor back through hoses and radadiator. Fan just doesn't kick on. I did connect fan to a power supply and fan kicked on so motor is good. Im guessing its a fuse (#16 50A) or a relay somewhere. If not that I might have a break in the Wire somewhere.
W
WSAYERS80
Orlando, FL.
Do you mean hood hinge assembly? If so, I have one
What Branch? I am assuming USAF. I was USAF got out in 2003. I now work on the Federal side. DoD/USAF Firefighter. My best friend is a USAF pilot, Fly's Hurricane Hunters out of Keesler AFB. Anyways I am done with my 02 GTS rebuild just need an assembly to mount the hood then its off to paint! I have been debating fixing mine or buying one. If I can get a good deal id rather buy.. What are you willing to do on yours?
shibbydude
