LPDesRoche
I have a grinding problem when shifting into 5th gear on my 98 GTS. All the other gears are just fine and once you are in 5th it's fine (doesn't pop out or anything). I wouldn't think 5th would be the first one to give me issues but it is. The problem was there when I get the car. But seems to have gotten worse with the install of a SVS short throw shifter. Not blaming the shifter by any means, I don't think the shifter could make just one gear grind, if the movement was off I would think all the gears in that direction would grind a bit (1st, 3rd, 5th)? Pulling the tranny is easy, but where should I go from there with it. Any suggestions.
