Hard brake pedal
tim bob
on my 94 rt I press on the brake pedal and it doesn’t move no movement at all. What could this be my booster and or master cylinder tia
Yes, most likely Master Cylinder if it doesn't move at all, Brake boost / vacuum line going to it if moves but hard.
T
tim bob
Ok thanks were would i find a booster any idea thanks
Dan Cragin
LA, CA
Gen 1 cars tend to have little power assist.
Make sure the brake booster is not leaking.
Engines that have bigger cams or lower vacuum at idle may have a firmer pedal.
T
tim bob
Dan thanks I have no pedal like something is blocking pedal to go down I will see if it’s leaking anywhere
SYDWNDR
I searched and searched for a new booster when mine went out, I ended up doing the "rebuild" service on RockAuto. Not expensive and not too bad for a turn around. However they gave me a different rebuilt one, because the color was not the same, but it didn't bother me because I'm not worried about preservation as much as I love driving my car.
I never heard of that as an option, especially thru RA. Post a link for people if you can. That is a wonderful option!!!
SYDWNDR
So, I didn't see it on the "parts list" like I found it originally, but I was able to go back through my history and found what it was I did, and here is the link. Not sure if RockAuto just doesn't link the service anymore, or maybe Cardone quit doing it. I did it in 2022 (is that really 4 years ago?) and it was $250 at that time.
Found this on the Cardone website:
Searched for "cardone 54-77021" on Amazon, and one came up.
