Harness anchor bolt size
Catwood
Is it 1/2-13 or something else in the Gen 4?
Thanks,
Carl
Viper X
Harness anchor bolts are the same in Gen III and Gen IV.
Not sure if it's the same as Gen II but could be. JonB at Parts Rack would know.
Have a couple extras laying around here somewhere .....
YellowViperSRT10
Florida
Thanks,
Carl
are you trying to find out the head size? or the length of the bolt? It should come with new bolts if you get teamtech. I have an extra bolt i can measure if you want. I think it is 1/2.
C
Catwood
I was heading off to the get some black ones at the store after work. I'm home now and have the one's I got from Jon. I"m planning on putting black forged ones in the floor so they do't show so much.
BennyBad
Miami, Fl.
:2tu:just finished installing driver and passanger harnesses, takes as long to adjust them as th install did. get a little black rustoleum and paint them. once there installed youd be hard pressed to see the attachment bolts. nice hint roll up the excess on the shoulders like a ******* and run a zip tie thru them to hold the shape and then they look like little pillows instead of seeing into the hole and the speaker bottom:2tu::2tu:
Snakenrooter
