Having trouble with side pipe covers
VIPER1996
Mt Pleasant, Ia US
I had my sidepipe covers painted last fall and they turned out nice. As the car sat this winter the driver side started to bubble in spots. I took the cover off and took it back to the body shop, they say that there is pin holes in the aluminum and had to weld in new aluminum in the bad area's. Why did it only happen on one side and if there were holes then why didn't they bubble before?
FRANK
Somewhere in southern NJ
Easy. The one side wasn't prepped right and a spot of corrosion was overlooked or not properly fixed, etc. and was subsequently primed and topcoated. Now , months later, the corrosion has come back. It is gonna be a real difficlut one to prove and most body shops won't cover rust/corrosion problems after a few months after the repair work is done. Read the fine print on a body shop's receipts etc. There usually is a statement about rust repair is on;y guaranteed for 6 months etc. If rust/corrosion isn't fixed right and totally removed it will blister through again.
V
VIPER1996
Mt Pleasant, Ia US
They are going to fix it for no charge, but just like you said if it isn't done right I will just have the same problem again. The next time it happens I will have to battle with them, if you know what I mean.
dansauto
gillett, pa, usa
Should have had me do them!! Sounds like the shop did not get the al oxide out orginally! Do a search on my name for a thread I posted a couple months back regarding repairing these
xeng yang
