HELP! A/C COMPRESSER & RAD ELEC FAN WON'T WORK & BATTERY LIGHT IS ON**HELP***
onebadviper
Jackson, Mississippi USA
HELP! A/C COMPRESSER & RAD ELEC FAN WON\'T WORK & BATTERY LIGHT IS ON**HELP***
I have a 1994 RT/10. Today while cruising I noticed the battery light on my dash came on.
At the same time the A/C quit cooling and the engine started to heat up. I stopped, checked under the hood and the electric fan had quit running. So now the A/C compressor & the rad. electric fan are not working. The battery is new & the volts gauge reads 14 volts with the engine running. What has happened? I checked all the fuses under the dash and all are good. I also checked the two fuses that are by the main electric box where the battery cable hooks up, and they are good too. I don't know what to check next. Please help.
Thanks,
Warren
(onebadviper)
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Re: HELP! A/C COMPRESSER & RAD ELEC FAN WON\'T WORK & BATTERY LIGHT IS ON**HELP***
Is the serpentine belt still on?
Is it turning?
Have you CHECKED the battery? It may be toast...not acepting a charge....
If the fan motor failed, be sure to put the NEW ENTIRE MODULE (Only $159 for shroud/fan/motor/pigtail) The motors in your fan are over $200 each!
PresidentEvil
