Vip-RT10
As most of the Tampa crew knows, I have been out for about 2 weeks now. I have a problem that persists in the 93 Viper and is not fixed yet.
1) I changed the battery
2) clutch pedal switch works (checked continuity)
3) starter relay is new, I replaced it.
4) I reset the alarm
5) had the starter tested
6) tested for continuity to the starter wires (steps with the key on starting)
7) cleaned all the wires that need to be ground (by engine, battery, ECU)
8) checked all the fuses
9) I tried moving the steering wheel
10)fuel pump works when key is turned to "ON"
11)accessory position on key works
Earlier, when the clutch was pressed down, and tried to start the car....voltage dropped, lights dimmed a bit, then factory alarm honked twice, but the engine did not turn over.
Now, doing the same, the voltage does not drop. Gerald helped me start the car the other day by jiggleing the key release lever and tilting the steering wheel. It worked a few times, but gave away in Orlando this last weekend.
It push starts fine, but nothing with the key. Now, the only thing to see is if the key cylinder is messed up, or if the ignition module is ruined.
To end this, it doesn't even turn over, any suggestions.....I can't sleep at night. Thanks in advance
