Help! Intermittent power loss (at speed!)
jfujita
Hi Everybody,
My 2001 ACR has been having electrical issues.
The story started when I noticed my car would lose all (Engine/instrumentation/clock/alarm/signals/lights) power when coming to stops at intersections/stopsigns. The power would cut out and the engine would die. By the time the engine had died, the power would instantly come back (the instrument lamps would go through their startup sequence and the stereo clock would have reset to 12) and I could restart the engine and drive away until the next occurrence.
I washed the car a couple weekends ago and when I tried to start it the battery had lost it's charge and the starter would barely crank and the car wouldn't start. Here's where things get interesting. I attempted to jumpstart the car from two separate other vehicles. Again, the starter would barely crank the engine (not enough to actually start). I tested the starter relay and discovered it was bad. I suspected that a faulty relay had discharged the battery, so I hooked the battery up to the trickle charger overnight and went to find a replacement relay. The next day after replacing the starter relay, the car would jumpstart fine, but the original battery wouldn't hold a charge. I wrote off the battery and replaced it with a new one and the car started normally. Hooray.
Fast forward to last weekend, while driving I noticed the instrumentation/warning lamps/dome lights would flicker sporadically like a bad contact was being jiggled and the car would momentarily lose power (engine would miss and buck, clock/instrumentation would flicker and reset, spedo/tach would zero, then come back). I was able to reproduce this at idle a few times before the entire electrical system failed and I completely and permanently lost power.
I was wondering if anybody has experienced anything similar. The battery is brand new and I checked the terminals and ground points for any play and found no issue. What could this possibly be?
-Justin
Jack B
NE Ohio
1. Make sure the inside of the battery cable connector is clean. Take some sand paper and clean the cable end of the terminal.
2. Check that the power terminal on the starter is tight and not corroded.
3. Make sure the cable connector at the PDC is tight and clean.
4. Another problem that is not easy to diagnose is the extension of the terminal on the outside of the PDC. That stud can come loose on the inside of the PDC.
slysnake
That's not suprising. These cars take a lot of juice and if your battery is low even a jump from a "normal" car may not be enough.
Edit: oops, just noticed you said your battery is brand new. What kind is it? There are several threads here debating the merrits of various battery brands. I have had a yellow top optima for several years with no problems. Do as said above as well and see if that helps.
Retart13
