V10 ACR
OK, now I don't know what to do. The dealer calls and says they figured it out and that it must be bad gas. They said I could pick the car up and that I should put "some of that engine cleaner stuff" in the gas and drive the car till it goes away. Does this make sense to anybody? There is no check engine light, so it is not likely the cam sensor (or can the sensor go bad and not throw a light?) and the fuel pressue checks out ok. I still suspect the cats are somehow clogged are causing back pressure when under load. How should they confirm that the cats are not fouled? Any ideas would be appreciated.
