onebadviper
I have a 1994 RT/10.
Today while cruising I noticed the battery light on my dash came on. At the same time the A/C quit cooling and the engine started to heat up. I stopped, checked under the hood and the electric fan had quit running. So now the A/C compressor & the rad. electric fan are not working. The battery is new & the volts gauge reads 14 volts with the engine running. Checked the battery volts and they read 13.2 & the alt. output is 14.7 volts with the engine running. What has happened?
I checked all the fuses under the dash and all are good. I also checked the two fuses that are by the main electric box where the battery cable hooks up, and they are good too. I don't know what to check next. I really don't want to take it to the dealership! Please help.
Thanks,
Warren
(onebadviper)
Thanks,
Warren
(onebadviper)
