Hesitation
604SRT10
I took my car out today and noticed the car pulls good in first, hit second and walk on it it kinda sputters and hesitates for a second then it goes, car is stock except k&n intake and mopar exhaust..could this be a fuel filter issue??? :dunno:
06blueviper
FL
possibly bad gas. i had the same problem and then changed my gas station. everything's fine now.
ILLSMOQ
SAN JOSE, CA
I had this problem too....back when the car had around 3000 miles. It happend a couple times. I wiggled all the connections under the hood , under the intake, back and front of the motor. Never had the problem again.
On the bad gas.....how hard is it to change the fuel filter? I want to change mine.
plumcrazy
ALL OVER
an easy for you to see if its a cat, is put your hand by the exhaust. you should feel air coming out of it. one will be a lot more than the other if one is clogged
Mando9595
