what are some power numbers you can expect with a roe blower with 7lbs of boost? mods are 70mm tb-1.7 t&d-catless-corsa and elites cold air intake system(much better than the vipair so its more than the 50 hp seat of the pants than the vipair).
Wouldn't "boost creep" be a good thing? Helps to develop more power at higher RPM, right?Boost creep: As the rpm goes up the boost is also slightly increasing...3000rpm is 5psi and it "creeps" to 6psi by 6000rpm....because the blower is pumping more air in it's higher rpm than the engine can move. Less likely to happen on a good breathing engine, ie heads/cam car.
Tony how dangerous would it be for me to upgrade to the 7lb set up? I have an 02 car and know the pistons are a issue but do you think it would be definent failure. I've also got the 1.7 T&D's.
