This must be a big night for t-stats...I just answered one other on the same topic. I think you'll find, unless you are fairly well modified or in a severely hot climate (spelled "not Buffalo"), your car will actually run better and quicker at the higher temps with the factory thermostat. In the older cars...'60's and '70's type vintage, changing thermostats and carburetors, recalibrating advance curves on distributors, etc., got you more HP. Todays on board computer controlled fuel systems and electronics, with Federal emissions regs, don't work the old way. That heat in the engine (controlled by the t-stat) was designed that way to maximize the BTU's generated by the fuel/ air mixture...it's actually quicker on a street, basically stock car (K&N's, smoothies, cat backs, etc....it's still stock)to run the standard t-stat.
