Whatever...
"you very well might be putting less torque...."
"Mights" are what grows on a chicken's a$$.
Meanwhile back at the ranch,
If anyone doubts, all they need to do is make a chart in excel like I have above, go get some actual measurements throughout the rpm range of two comparable engines, and fill the data blanks in. (e.g., formula one engines with 12,000 RPM limts are not comparable to V-8's with a 7,000 RPM redline.)You should be able to discern that, for example, when comparing the new LS-7 to the existing V-10 platform, when you measure torque you can multiply it by 100 and divide by two then divide by 50 and you will have the same number as your horsepower.
It will also be the same value as your torque. You can multiply & divide them by whatever you wish, as long as they are the same numbers. What's the point?
None of this has anything to do with acceleration, which is entirely dependent on the geometry & weight of the vehicle that the engine is intended to propel.
And that's all I got to say about that. Over Roger; Roger Under.
