I HERE A KNOCKING AROUND 2500 TO 3000 PLS HELP
v10sloboy
atlanta georgia
I DROVE MY CAR TODAY 94 RT10 AND NOTICED THAT THE ENGINE KNOCKS AROUND 2500 TO 3000 RPM IS THIS THE VALVES OUT OF ADJUSTMENT OR IS SOMETHING MAJOR WRONG ANY HELP WOULD BE GREAT. I HAVE GOOD OIL PRESSURE AND THE OIL LEVEL IS FINE AND CLEAN
Jumperman18
Tucson, AZ (school) Rancho Palos Verdes, CA (Home)
The knock could be a pinging or preignition of the gas in the cylinders. Could be attibuted to a bad batch of gas or ignition related. Dont worry its most likely not a valve train related problem or you would hear loud clicking at idle also. Try a new set of plugs, see what happens.
V
v10sloboy
atlanta georgia
I TOOK OFF THE #7 PLUG WIRE AND THE NOISE WENT AWAY ALSO PULLED PLUG OUT AND IT BROKE INTO TWO PIECES DONT KNOW IF THAT IS FROM ME OR THE PLG WAS DAMAGED
HOdbleFman
Hurricane, WV
If it is broken, there is a reason. Plugs don't just get old and break. Pull the other plugs and check their condition. It could be detonation causing your problems. Do a compression check as well to rule out any damage.
V
v10sloboy
atlanta georgia
the engine had a arrow rebuild 4000 miles ago it is at the dealer lets se what they do. the engine is damaged internally. the noise is louder than before and the car has lost power
Mando9595
