Installation of MSD Fuel Pump Booster
SYNFULL
Bucks Co, Pa
Hi,
I bought one of these in preparation of a s/c setup and have some questions before I start.
The switched power to the relay #86- Any reason I can't use the same power line going to the vec?
The line from the msd relay 85 to the "original fuel pump relay" - I get that from the pcm - grey connector, pin 19 brown w/ violet?
Do most of you install the msd relay, and the pump booster in the engine compt. on the flat top where the vec is installed?
Where do you pick up the wires to the fuel pump that have to be within 12" of the pump?
Any reason I shouldn't install this without the s/c installed? Can I just keep it turned down, or does it need to really be dialed in with the fuel pressure and a boost gauge.
Thanks in advance for any help!
Gary
rlamorte
