Is AC possible in a non-AC GenI RT-10 ??
PaulH
Philadelphia
Hi all,
Is it possible to install air conditioning on a 1994 RT-10 that did not come with air conditioning?
okay, i know anything is POSSIBLE.... is it possible WITHIN REASON?
sorry if this has already been covered.....
thanks,
paul.
Ulysses
San Diego, CA. USA
You might be able to get parts and pieces from vendors that sell used Viper parts. At one time, Dodge did sell the kits, but they are no more. So yes, it is possible.
RCKTMN
Massachussetts
Hi Paul,
I did the conversion myself two years ago. The car is simply 'missing' the A.C. parts. The heater housing, for example, is the same. You just need to add the A.C. items into it. Your dash control is the same. It has a small black sticker covering the A.C. "snow flake" location. All the other items are simple bolt-ons as well. Basically, the Vipers Heating and A.C. systems were designed in a modular fashion.
The true trick is to acquire all the items you need. My understanding is that Chrysler stopped making the add-on kits years ago. Therefore, your only out is to find a used system or buy the parts individually from a dealer. The used route is the best. You can probably find someone on here who has removed their system for performance reasons. Another good source would be Jon B. at the Parts Rack, or Viper Parts Larry, to name a couple.
As for installation, your Viper tech and dealership should be able to direct you to whatever shop services their cars. I have to tell you that it was definitely worth doing. The car is much more enjoyable with the A.C. in it.
Good luck,
Paul :2tu:
P
PaulH
Philadelphia
thanks for your replies!!
any ballpark estimates to about how much (including installation) it will cost?? perhaps a range (from least expensive with all used parts to most expensive with all new parts)?
THANKS AGAIN!
Jeff Torrey
Plaistow, NH USA
It will cost you at least $2500. Could cost you $4000.
Just depends on how many parts you can get used. Your going to need a new dryer anyway, so don't buy a used one. I got some parts from a track car, the rest I got through Tator's Dodge.
Its possible but I don't know if all the parts are available. Good luck.
viper2002
