Is This For Real
kwkshift
Scottsdale, AZ
Thats an old one...
Basically, it's a resistor that you install inline with your Intake Aircharge Temp. sensor, or IAT, that tricks the ECU into thinking that the car is running in a cooler air temp than it actually is. Therefore, the ECU just gets more aggressive with timing, fuel delivery, etc.
It's BS, basically. You can get a resistor at radio shack for 99 cents that can do the same thing.
SidewinderGTS
Thats an old one...
Thank you for your reply.
Is this safe? If so what type of resistor do I need and how to do it?
opnwide
austin tx usa
Just remove your temp sender, put it in the fridge for a while, and measure the resistance. That should do it, right?
ViperBite
Orchard Park NY
With all the usual reminders that you assume all risk for any mods, a 0-10K variable resister (radio shack) will allow you to drop your "temps" during summer (10K) and then back to normal during winter (0K).
I had to install one due to a unrelated problem. I had high RPM cutout and by adding a resistor to the IAT circuit I got rid of the problem.
10K resistance drops your readings 20-25 degrees F as I recall.
I think ambient from the IAT is around 8K ohms.
Now as to whether or not this is safe, I can't answer that. I can tune my Viper so I am not worried about effects of this mod. In a stock condition can't say.
IMHO, if you don't have the smooth tubes and K/N or other filter, do that and forget this.
SidewinderGTS
Thank You. I will take your advise. :2tu:
Bobpantax
Miami
The problem is in colder weather you will need to take it out.If you do not,it could cause pinging.
Snakenrooter
