Just finished another Water / Methanol tune at 10 psi, graph inside
Sean Roe
Jacksonville, FL
It's always nice to have over 600 RWTQ by 2,000 RPM :)
This is with the green top 50 lb/hr injectors and a stock fuel pump with no voltage booster (note that the injectors and pump are maxxed out at 5,500).
Regards,
Sean
SUN RA KAT
Guest
What mods are on that engine?
Do you have a dyno graph of before and after stock heads and your ported/polished heads?
Sean Roe
Jacksonville, FL
I may not know everything about this car as all the parts were installed by the customer, but here's what I think it had:
Stock airbox modded to 3" outlet with 3" tubes and 70 mm throttle bodies, standard blower kit, 1.7 rockers (don't know what brand), I think it has a set of modified heads on it (could be ours or built elsewhere), stock "708" cam, maybe an aluminum flywheel, Balenger headers with high flow (or no) cats and 3" cat-back exhaust. All in all, a fairly standard combination with a 3.07 stock gear.
We tuned the car for him about 8 months ago with 8 psi. I think we picked up about 70 RWHP and TQ with the pulley and WM tuning.
Regards,
Sean
Shelby3
liu;g
I didn't think you could get to 700 RWHP with the stock fuel pump. :eek: :usa:
KenH
Portland, OR, USA
That's a heck of a flat A/F tuning job. Nice to see the Belangers did not seem to create any restriction at that power level as well, as some have suggested.
