Machine shop broke my heat sensor off in my heads.
Early93Viper
Took my heads to a machine shop that seemed to do a great job but broke my heat sensor (Circled red in pic) off in my heads.
Questions:
1. They say my heads are interchangeable. That I can switch them and put a new heat sensor in the other head and be fine. Is this true?
2. I went to the Dodge parts counter and tried to find the right part number for the Heat sensor. They were not sure but thought is was part number: J3230408 Is that number the correct number?
charlesj
Bethlehem, PA
:mad: can't tell by your post but are they taking responsibility for fixing or not? they broke it, they should fix it. :mad: or am i just crazy and it doesn't work that way anymore???
E
Early93Viper
No they say that they didn't do it. If it is an easy fix I will just fix it. If not I will take it up with the Machine shop.
Bill B
Plantation, Fl. 33323
They all break. Have them remove the old one so It doesn't give you any trouble. The heads are interchangeable so that doesn't matter. The new part is under $10.
E
Early93Viper
They got most of it out. Just my threads look stripped. Will this be a problem?
Dan
Bill B
You can try and chase the threads with a tap and use it again, if that doesn't work. Drill it, tap it, plug it and use the other side.
Jack B
NE Ohio
That is the idiot light sensor, the temp gauge sensor is near the thermostat. If anti-seize is not used on that sensor it is also impossible to remove without breaking.
ctrengine
