Maintenance service for 06 Supercharged Vert with 21, 500 miles
ViperCobra
Hello,
Just want to ask what services should be done at about 21,500 miles? I only drive my Viper about than 1,000-2,000 miles/year. I haven't done the oil change yet for about 2 years now. I will be doing the oil change this month. Just wondering what other maintenance should be done. Thank you! :)
Do you know what fluids were changed when? Some are time dependent like brake/clutch fluid and coolant. When in doubt, it is safer (and cheaper over the long haul) to change all of the fluids.
V
ViperCobra
Thank you Steve for your reply. I believe the last fluid were changed around 16,000 miles but not positive though :(. I will have it fluid change then, is the coolant, brake/clutch fluid? are there any other fluid changes? do I need to change the differential and transmission too? Also, the supercharger fluid too I assume? Thank you :)
While I respect the involved costs, I would also change the diff and tranny fluids as well. These fluids see real heat stress, especially if tracked in the past or you have plans to do same in the future. Your supercharger setup makes a bad-asp into a beast !
USMCLY
if you have the novi2000 then the oil is from your motor oil, if you have the 2500 then you need to replace the supercharger oil
V
ViperCobra
Thank you. I do have the Novi 2000. So is it separate to do oil change and supercharger oil change? Thank you.
USMCLY
the Novi2000 is not separate. It uses the oil in your motor.
