MATCH MOUNT TIRES GOOD OR NOT??????
3snakes
has any one done this. could some one tell me how this is done.
Larry Macedo
Sanford, FL
Match Mounting Viper rims/tires is an excellent idea since the contact patch is anywhere from 10-13 inches in width. Your installer will usually find the high spot on the tire and the rim using a runout gauge and oppose them 180 degrees to avoid radial runout. Some of the better tires are color marked for this purpose as well.
3snakes
MAC thank you for the input. what should i pay for this. also i called a couple of tire stores they had no idea what i was talling about. do they call it somthing else?
Mando9595
