Mopar Performance Parts for SRT-10's
Viper Wizard
South Salem, NY USA
Mopar Performance Parts for SRT-10\'s
The new Mopar Performance catalog is here, and lots of new goodies for your SRT 2003 & 2004!!
Race Engine Controller #P4510172
Camshaft #P4510171
Underdrive Crank Pulley #P4510177
Drive Belts for Underdrive Pulley: W-A/C #P4510224 WO-A/C #P4510225
Race Oil Pickup #P4510174
Race Limited Slip Differential 3:07 #P4510170
Performance Side Exhaust #P4510176
Heat Shield Kits:
>Ball Joint Kits [96-04] #P4510144
>Tie Rod Kits [96-04] #P4510161
Differential Oil Coller #P4510173
Short Throw Shifter #P4510168
Lightweight Flywheel #P4510169
Ring and Pinion Sets [00-04]:
>3:55 #P5007525
>3:73 #P5007526
>4:10 #P5007527
High Durometer Transmission Mounts #P4510179
Spherical Bearing Control Arms #P4510241
Solid Steering Gear Mounts #P4510089
Aluminum SRT Wheels 5-Spoke:
>Front 18"x10" #P4510620
>Rear 19"x13" #P4510619
"No replacement for displacement" :2tu:
GR8_ASP
Re: Mopar Performance Parts for SRT-10\'s
Any idea on prices (both retail and discounted)?
2charmed
Chula Vista, CA USA
Can I get installation by the Wizard here in Kalifornia? ;)
Why would we need race performance parts for SRTs??? Hmmm
2Charmed
V
Viper Wizard
South Salem, NY USA
2Charmed
My plane is warming up right now! :D
Don't touch that dial. ;)
2charmed
Chula Vista, CA USA
[/QUOTE]
[/QUOTE]
Cool!
Viper 24
Bend, OR
any way to access this catalog online?
Casey
Valparaiso, IN.
Chuck, what about for the SRT-4? My brother wants to be able to surprise people!! :laugh:
Viper 24
Bend, OR
Thanks Mike! Does anyone know if Mopar has a set of 3:55 gears for the SRT10? It looks like the gear assemblies are for RT/10 and GTS.
Frank Parise
Tucson, Arizona USA
The brake rotors and calipers on the SRT-10 and the Comp Coupe are identical. Why not use the race pad from the Comp Coupe? The pads are identical for both front and rear calipers. Part #04898012AA in the Comp Coupe spare parts catalog. Price is $205 per axle set ($410 for all 4 corners). Viper Headquarters phone# is 888-960-3333. I'm not sure they will sell race parts for a street Viper, but you can try.
PartsRack Does! And quite a few of you drag racers are breaking the OEM diffy cross-pins inside the posi. The PVO SRT-10s that ran at VOI-7 broke 2 of em.
So our gear kits now include new, hardened SRT-10 cross pins, ($60 value) internal and external rebuilt service parts, as well as a pre-calibrated speedo kit, something MoPar never has offered. "Well Under $700"
"#1 Bang-4-Buck Performance Upgrade"
IN THE recent PAST.... Numerous examples of MoPar-announced Part numbers for Viper, but no parts ever came out! {Vapor-Ware, not VIPER-ware.) Even of a price appears, it's no sure-thing. Stay Tuned.
knuk
Jon, what sort of extra performance can I expect if I were to install the gear kit? Does it have any effect on my factory warranty?
V
Viper Wizard
South Salem, NY USA
So True!
HEY, Mopar Performance STAFF: You released this Catalog and we're ready to order.
This CHAIN has been Pulled before! :mad: So get off your chairs and make it SO!!
1) 16% faster acceleration in all gears
2) "feels exactly like 80HP" for under $700 !
3) makes your de-facto 4-speed a functional 6-speed.
4) Lowers top end from 196 mph to 165 mph
5) only affects warranty on the rear end itself.....but SAVE the OE gears!
6) Stronger than OE
knuk
Thanks Jon.
GR8_ASP
Jon is the 165 mph top speed calculated or measured? I will post some graphs I calculated using stock and 3.55 ratios. My calculations indicate about a 10 mph reduction with 3.55. It is different than a Gen II as the SRT has bigger tires, higher stock horsepower and different drag (more than GTS and less than RT/10).
GR8_ASP
Here is what I have calculated.
Stock (3.07 diff):
and with 3.55 differential gears:
SnakeEye
Austin, TX
Nice charting work showing the differences.
Thanks.
SMHOD
GreenBay,WI
Jon,
I have switched to a 3.55 differential but have not had a chance to drive the car given winter conditions. I had asked if the speedometer needed any modifications because of the gear change. I was told that the speed is measured at the wheels so no speedometer mods are needed. What is your speedo kit about?
Thanks,
Scott
GR8_ASP
Scott don't know who told you that but they are wrong. The speed is measured at the transmission and read by the engine controller. It does not compensate for diff or tire changes. Seems to me the calibration boxes have run a couple hundred on top of the differential change itself. Under $700 sounds like a reasonable deal overall. The big question then is how much to have the parts changed out and will the installer and Jon guarantee acceptable differential gear whine (my biggest concern with non-OEM parts).
SMHOD
GreenBay,WI
Ron,
Thanks for the info. I had sent my differential to Heffner in Maryland for the gear change and he had told me that. I will have to give him a call and get this straightened out. I certainly would like the speedometer to be correct and not have to constantly multiply by a factor. I am guessing that factor would be 3.07/3.55 or .86.
Thanks again,
Scott
GR8_ASP
That plus the odometer would be off by the same amount. Definitely worth getting the speedo cal kit.
SMHOD
GreenBay,WI
Very good point.
Thanks,
Scott
treynor
Redwood City, CA
So how can one tell if the posi "pins" are broken? Do you wait for the catastrophic "crunch" and then have it towed, or are there warning signs?
SMHOD
GreenBay,WI
I just talked to Jason At Heffner Performance about the speedometer issue. He said that that transmission on an SRT does not have any monitoring on it for speed and that it is done at the wheel. He had a transmission out in his shop and went to look at it to be sure. He said he has measured the speed with GPS with different gears and it matches the speedometer +/- 1-2 MPH.
Scott
GR8_ASP
Okay, I admit I was speaking from the Gen I/II era. I will have to check the service manual. With ABS it is possible to monitor at the wheel. That does make the mod a bit easier and cheaper.
On second thought then what does JonB include with the pre-calibrated speedo kit?
SMHOD
GreenBay,WI
""On second thought then what does JonB include with the pre-calibrated speedo kit?""
That was my original question. I guess I will have to verify my speed just to be sure when I finally drive the car.
Scott
GR8_ASP
Confirmed. The PCM gets the vehicle speed signal from the ABS module. Sounds like a great benefit for anyone changing gears.
No members online now.
JpKL
