More STOCK GTS Times tonight ----->
Steel00GTS
Palm Beach, Fl
Moroso... crappy crappy track. It rained lightly off and on till after 9. I only got 4 runs. Still stock GTS
best run was a 12.10 @ 119.07 with a **** 2.02 60'
I had a 12.1 @ 118 1.99 60' also...
I wanted 11's SOOO bad.. All of my friends were haven't traction problems. My friends Heads/Cam WS6 took me 11.8 @ 118. I'm pretty sure with a better track night 11's shouldn't be a problem... :mad: :mad: :mad: :mad:
I weighed it also 3350 lbs. with about 1 gal of gas. Not bad.
Steel00GTS
Palm Beach, Fl
All of you who are getting 1.7 and 1.8 60's..... are you just feathering the clutch a little bit at 1800 - 2000 rpm and letting the torque take it? Or are you playing the clutch a lot more and higher RPM's?
Russ M
LA, California
What is done to the GTS far as weight savings goes? It is considerably lighter than a stock one. Or the scale is out of wack.
SimpleJack
