MORE USED PARTS AVAILABLE
Cape Coral, FL
-ACR Oil Filter Adaptor w/new gasket $200.00
-Random tech Metal Substrate Cats (2500 miles, THE BEST) $400.00
-B&B Cat-Back, Virtually new, one cosmetically damaged section $800.00
-Crank Position Sensor $150.00
-Throttle Position Sensor $40.00
-MAP sensor $60.00
-Idle Air Controller $75.00
-Coolant Temp Sensor $25.00
-Serpentine Belt (4K miles) $15.00
-Turn Signal/Flasher relay $10.00
-Fuse Box & front wiring harness (complete, but needs 1 pin in headlight connector replaced- I repaired a section of the harness that had been cut after I removed it. Fits 01-02
-Underhood coolant bottle $15.00
Prices above are SHIPPED in USA-48.
Feel free to make reasonable offers.
Thanks!
Cape Coral, FL
Better deal on the cats:
Might want to factor in the cost and hassle of finding someone who CAN modify them back to fitting a standard setup.
PS- just realized I listed the wrong set of Cats. The cats listed above have about 400 miles, not 2500.
