Most power with Gen II injectors?
CTBYTC8.0
I cant find any definite answers so-
I am building a Gen II N/A stroker. How big of a stroker? I wont know till I can get Greg Good my crank.
Its stock bore, JE flat top forged pistons and Oliver rods.
Going to go with Gen III heads Ported and have Greg work a lil magic on them.
I have been told by a friend who owns a 99 GTS that he is putting down 606RWHP on stock injectors but wasnt sure if the tuner had changed the fuel pressure.:crazy2:
Will the stock Gen II injectors adequetely support 600 RWHP? Maybe with a increase in fuel pressure?
Whats the most anyone has seen N/A with stock Gen II injectors?
Jack B
NE Ohio
They start going static at about 500 rwhp. If your friend is at 600 hp he has no ability to tune the a/f. Keep in mind 500 rwhp is almost 600 fwhp.
Fort Lauderdale, Florida.
Depends on your target A/F. My Gen II N/A motor makes 600 rwhp SAE corrected. This is with stock injectors, was on a SCT flash, now on a split second tune.
Let Greg do his magic and when your ready to dyno tune SLOOOWLY creep up on the throttle and rpm; you'll know where to go from there.
It won't hurt to put a Walbro or new style Aeromotive fuel pump in the stock basket.
Greg will do you proud!
Best of Luck!
:drive:
