My engine job begins.......Again!
carl B
United Kingdom
Got the block back from the machine shop today
Carl
Bonkers
DelaWhere? USA
You know, one of the definitions of insanity is repeating
the same action over and over again and expecting a
different result each time.
Just messin with you Carl - what's the expected result this
time around?
C
carl B
United Kingdom
Well I went as far as I could with the Roe setup so I sold the kit to a fellow UK member and have now gone with a CPE DIY Twin Turbo kit
Paolo Castellano
Elburn, Il, USA
Carl, I am glad to see your motor is coming along!
I am working hard to get your turbo system finished!
Let's both keep up the good work! :headbang:
C
carl B
United Kingdom
well got the ARP studs in now
next job is to fit the pistons and rods
Happy days!
Carl
Camfab
SoCal
Carl just a quick observation. In the first photo in your thread you show your block back from the machine shop with what appear to be bolts in the main saddles. Your next photo shows ARP studs. Did you not machine the mains with the ARP studs installed? Not sure if this procedure is different on the Dodge, but that would be a huge mistake on a Chevy. I'm not trying to be a smart @ss here, just really curious.
ROGUE
SoCal
you're absolutely correct that it should be machined however it will be built. In the very least I would double check all the main clearances with the studs to be sure it didn't distort the caps.
C
carl B
United Kingdom
I checked for bore ovality with both bolts and studs and could see no difference with a bore clock?
Hey Paolo!!!! I cant wait!!
Carl
C
carl B
United Kingdom
She is all back together!!!
C
carl B
United Kingdom
SKY1960
