Mystery rod
Clifton Viper
Clifton, VA.
I was fishing around in the trunk of my 02 RT/10 to pull out the factory amp and I found a 5'6" fiberglass rod in the back of the trunk. It is black, 1/4" diameter made of fiberglass or carbon fiber with rubber endcaps on either end. It was bent, with it's arch hooked in with the electrical wire harness which run along the top/back of the trunk.
Is this a Viper piece or a momento from the former owner? :confused:
SylvanSRT
Sylvan Lake, MI, USA
it is a piece for the factory tonneau kit. which may not have been installed. look for the plactic cup/hooks screwed into the windshield sides, it you have the other pieces to it. if not dont bother installing buy a cockpit cover instead easier and quicker.
C
Clifton Viper
Clifton, VA.
SylvanSRT - that would make sense. I have the tonneau kit but it has never been installed (seems useless -- I have a cockpit cover too).
Thanks alot.
Mando9595
