Nail in tire - SRT10
ssviperfl
My front tire on my '05 SRT 10 (michelins)picked up A NAIL, not sure if it has penetrated into the tire (maybe just a nail head with stub), seems like no air loss, not sure what to do. Can a run flat be repaired?
Racer Robbie
Guilford, CT-USA
I use this NAPA kit to plug my tires. Michelin says not to plus run flats. This is why I run Non Run Flats.
710-1637
FLAT TIRE REPAIR KIT
Robbie
Omaha NE.
The tires can be repaired as long as the puncture is not near the sidewall. The speed rating for a repaired tire though is not retained. Use your best judgment with speed after the repair but you will probably be fine.
Racer Robbie
Guilford, CT-USA
Just to note that I have repaired both rear tires and have 5000 miles on the repair with the kit above. This kit has rubber plugs that are shaped like a mushroom. The mushroom head is injected from outside of the tire into the inside of the tire with the gun included in the kit. There it expands and seals the hole.
Robbie
YUSUKE
