If you track your car...go gel...if not, consider 75 series Sears Die-Hard Gold ($80.00, good warranty)...SOME Vipers will take 78 series, some won't...so, I go with 75 series in all of our Vipers.
i went optima, but needed to cut down the top post, a bit.
used a file no big deal...but..WARNING if you cut too much you will ruin the battery.
Mine is fine but took 2 trys. lucky for me the part store took the two mistakes back as
defects....
I just replaced mine. What a nightmare . I'll never try to fit an aftermarket battery again. I cut the posts like an idiot and It wouldn't work. I tried to take it back and they said SORRY. Use the OEM .
I used an Optima and can't be happier but I hear I got lucky as heck that it fit right in with no problems. I even had 1/4 or so extra room on top.
If I were you, I'd buy the Optima and the Gold. Take out the old battery and try to fit in the Optima. If it goes in like mine did, return the Gold. If it gives you troubles, return it and use the Gold.
Got a new one from my local Walmart with over 700 cca's..i think I paid $59.99 for it. Turns the V-10 over effortlesly...
Just take a physical measurement and head on down to the local white trash Walmart and buy the same size with as many cca's as possible!
Just slipped a DieHard Gold 75 in my '98 GT-2 last night. The fit was a little snug, but went in without too much drama. Paid $79 (plus $7 for not having an old battery to trade in on the new one) at Sears.
Get the Optima.The battery tray may need to be stretched a little using a bottle jack.Don't cut the terminals.Just do a little stretching.Why Optima?Doesn't puke acid out on to your car. Bruce
Bruce, optimas ****, they don't work. Tried 2 and both the same,,,,,, junk. Had 2 buddies with same prob.Not worth the price when you have to replace 3 times a much. Get a reg. battery and keep it clean.
