Need a used drivers stanchion cover for 98 GTS
plumcrazy
ALL OVER
i think thats what its called at least. its the vertical black panel that the drivers side door popper is attached to. I really only need the vertical rubber window gasket but im told they are all one piece.
i need a good used on if ya got it.
PM me here or email me at [email protected]
Schulmann
Canada
Plumcrazy,
Why do you need a new stanchion ?
Did the rubber separate from the plastique ?
Two things: this staff is hard to find and is very expensive.
However if you have an issue with the stanchion's rubber I have a fix for this. Tell me and I will update this post with the required information about the glue and all that staff.
P
plumcrazy
ALL OVER
it seems to have blown off and is lost. I assume i can fix it if i had the rubber gasket but i dont...:(
but update it anyways, id be interested.
Eric H
Raleigh, NC
I have one i could sell relatively cheap that has all the pieces but needs to be "fixed" because the rubber came loose, but if Shulman has a fix it should be pretty easy, other the stanchion is all in one piece. I dont want to sell just the rubber however because then i have a worthless stanchion.
Schulmann
Canada
I spent $50 on glue before finding the right one.
Once I am at home I will post the pics and all the information required to fix that part.
Schulmann
Canada
The glue need to fix these two parts togather is:
Permatex
PermaPoxy
Plastic Weld 5 min Ciment (25ml)
This glue is really strong.
Once the parts are fixed togather, the back of the sanchion needs to be smoothed. I use standard body filler and once everything is smoothed paint the surface. It doesn't need to be professionaly painted since the back surface is not visible. (Unfortunately I don't have picture on this staff). Once the job is done the sanchion looks like new.
This glue needs to be smoothed with body filler.
B SNAKE 1
I re-glued my with only taking off the interior plastic trim & door panel easy. I took a Dremel tool & cleaned both surfaces went to this website~~
www.bindingsource.com
Ordered
(1) 3MDP-100CL $11.54 worklife 5 minutes, handling strength 15-20 minutes cure time 24-48 hours @ 73 degrees F
(1) 3MEPXAPPL $39.75 EPX Applicator for perfect mix
Home depot (4) small plastic clamps worked great looks factory. :cool: :cool:
slaughterj
Ordered
I tried to search that site for the 2 product codes you provided, and nothing comes up - help?!
QUICKV10
IL
Is the rubber moulding part of the stanchion cover, or could u order it seperate
