Tom, you have a good start. get work history from Dodge and check owner history. Check out the following sites for TSB's and recalls for what you are looking for. They can give an idea of potential problem areas as well as information. Things the 96-97 car should have had done may be replacing the intake gasket, changing the trans fluid to minimize the ngr, update the cooling fan, flash on the ecu, etc. as applicable.
http://www.nhtsa.dot.gov/cars/problems/
http://www.alldata.com/TSB/yr.html
Lance has given great warranty prices. worth an e-mail to him at:
l.delk@quinnoftulsa.com
Good luck and have fun.
