FATHERFORD
I took these pictures of my 97 GTS for another reason, but I started noticing some things when I was looking over them..Besides that the engine bay being filthy.
1. Any type of belt is recomended? Apprently this belt is short a rib from the pictures
2. Are these factory pullies? I was looking at other members pictures and saw some black ones, so I was curious if these were aftermarket.
3. This car has an aftermarket aluminium raidiator on it(assuming fan also). Yesterday I was driving it in 85 degree heat with high humidity. The temperature gauge sits in the middle in stop and go traffic. I turned on the A/C and it creeped up to a little before the mark between 190-250.. Guessing that mark is 225, so it was around 215. I'm worried when its 100+ degrees outside it will get even hotter. As soon as I started moving it dropped down to 185-190.
Suggestions on the "over heating" problem while sitting in traffic?
4. I noticed the fuse panel has a red wire tapped into it. Can't for the life of me see where it goes to. Ideas? I haven't got down and dirty to follow it.
5. Curious...Does anyone know how much clearnence there is between the hood and the top of the throttle body/intake area?
Thanks!
Thanks!
