Nitrous Explosion
Ivory
Madison, WI
Ok, I had to make you look. Trying to avoid a Nitrous Explosion on my Gen 1.
Gen 1 owner with 40k on strong stock motor, tubes/filters interested in installing a NX 150-300hp shot kit on car. Want to hear from other Gen 1 owners about installation.
How long to install?
Special tools to install?
Plug types/gap?
Optional items necessary above the base kit?
Undocumented tips/tricks
HP generated with jet used?
Additional safety features installed?
How many 1/4 mile runs on 10lb bottle?
Is a bottle warmer necessary?
Is a remote bottle opener required?
What to watch out for with A/F ratios?
Is this a do it yourself install and go without a dyno?
Any help would be appreciated.
Fishtail
PA
With so many questions why not find a good mechanic that works on race cars to help you?
Nitrous has always scared me. I don't know if I'd be up for the challenge. Hope it works out for you
-Lou
RedEnuf93
Lancaster, PA
I have a Gen 1 (1993)with NX Express system. You could call Lee Dove, he was very helpful with my kit!
I took it slowly and wanted to do a A-1 job, so the Viper was on jackstands 2 weeks. Yes, it can be done in one day too... I wanted to find S/S nuts bolts, fittings, most of the time went into figuring out best way (aestitically and functionally)to do the "plumbing".
No. Good wrenches is a must, unless you want to damage anodized fitting.
Plug types/gap?
NGK ZFR6F-11 Stock #4291, Gap between 0.30-0.33
My understanding is that with 100HP shot you could use regular Champion plugs.
I chose billet aluminum bottleholder and dual tanks. I chose not to use the cheesy looking NX switches and bought better ones. Two NOS purge nozzles mounted in front.
No.
562HP/712TQ with pig-rich mixture. 52-33Jets (200-shot).
I cut my own jets for "in-between" sizes to further tuning, tomorrow is dynoday, so I'll let you know if I melted the pistons or gained power.
I chose not to use the fuel pressure sensors.
None yet.
Absolutely, if you want to keep a constant optimum pressure in tank.
Too much hazzle and possible issues with them functioning properly. I open valves when car goes out and close when it is parked.
Lean mixture... It will melt catsize holes on top of the pistons.
No. It is a do it yourself if you have some common sence and decent tools. A dyno is a must to verify your A/F ratio. Better safe than sorry.
Hope this helps!
RedEnuf93
Lancaster, PA
Here are some numbers from a 1993 Gen 1 for you:
I dynoed the car today and it made: 597HP/ 768TQ
Not bad, eventhough I wish it would have made the lousy 3HP more....
I
Ivory
Madison, WI
Congrats! Wow sounds great. I can't wait to get a system. My car is mildly modded and now my fellow Gen 1 brothers are stepping up to Super Chargers, I need a little extra umph.
I'm planning on NX 300 shot system with 150-200 jets, bottle warmer, purge valve, and fuel safety valve.
Will order in the next few days and find an installer.
Glad to see that you are making good horsepower!
Ivory
VIPER D
dutchess county, ny
This is what my stock motor gen3 mamba made with a btr nos/propane setup thought you might want to see it.
vd.. :2tu:
Qdog
