nitrous viper rt/10 94
tito
Panama
Hello, i own a 1994 rt/10, im running a nitrous express 150hp shot... im planning to get the vec2. My goal is to run the 300hp shot... any recomendations?
thanks...
pedro
N.Y. USA
If your looking for a good system get a BTR Nitrous/propane system they work great.I have one in my car im using a 150 shot no problems
Casey
Valparaiso, IN.
thanks...
That's a BIG shot! Make sure you get it tuned in properly! And get some stickier tires! :D
dansauto
gillett, pa, usa
it can be done, but better have it tuned. That is bordering on the limits of your stock fuel system and the gains arn't that great over a 200 shot. I think the BTR kit is a little safer at that level as the propane adds octane. Laure-chime in here, this is your specialtiy!
T
tito
Panama
well, thanks for the help... i will try the 200 hp shot... by the way, im using the kumho ecsta v700, those tires are great! in second gear i shot the 150hp , and no tire spining...
T
tito
Panama
the car is running 12.5 no nitrous
11.6 with nitrous
In my country, we dont have a great track... so the 0-60 feet times are bad.
TOOOFST
Barrington,il
Anything over 150 shot should be a progressive setup,or put your order in for a NACA duct.
I doubt you'll get your monies worth from the vec2 without,any head/cam work.You can buy the window switch,and dyno tune the nitrous with jets,the ONLY way.
countourcafe
