rollymohan
- Joined
- Mar 17, 2012
- Posts
- 54
- Reaction score
- 0
Is there a nitrous kit available for cen V
You guys aren't purging... With a plastic intake!?!?!? Ticking time bomb!
i am runnung nitrous in my srt8 with a kit i made up for the last 7 years with no problems.i used a diablo to retard timimg.my brother uses ntrous on his 02 gts on a stock engine and runs 10.50.however if i cannot retard timing on my gen v i will need a propane kit.You see i wanted to do at least 200 shot.
Yeah, he crashed his car at the strip his last run.The G5 is uncharted territory, however, there were several G2's running a 200 shot without timing retard. Running at 10.5 to 11.0 a/f slows the rate of ignition and cools the charge, it has a similiar affect as pulling advance. Again, that was a G2, no matter what the car, to be on the safe side IMHO you have to run an onboard a/f logger. That is way cheaper than a rebuild.
There was one G5 running a 200 shot without timing retard, however, he has not posted for several months. The PCM was pulling power near the high end on the dyno.
I simply can't believe that NO ONE here takes issue with those of you saying purging isn't necessary!!! LOL!!!!
99 times out of 100 you won't have a Nitrous backfire.. But that ONE TIME you do... Well, been there, done that! Learn from my mistake!! Do a quick purge through the motor once or twice before you whack it! Trust me!!! It gets expensive when luck runs out!!!
You guys have all the answers...
