Compensating
Smelled the infamous smell.... dreaded the infamous thought of having bad headgaskets... The valley under the upper plenum was full of coolant...
almost freaked out...
after disassembly... found out it was from a bad thermostat gasket..
went ahead and replaced upper plenum gaskets ($32.00 at dealer) and swapped in a roe 172 thermostat and gasket ($49.00 with fed-ex)
oh.. and dont forget the PCV valve... ($2.43 at walmart )
