O-2 sensors (Extended wires for headers)
a) If you have low miles good O-2 sensors, splice and extend the correct guage O-2 wire by 18". Thermal wrap the wires.
b) We also offer a brand-new correct custom-made Nippondenso sensor (at $200 ea) correct length. Needs two. (use w/ HMS or SVSi headers.)
c) You have a 98, but The Year Matters.........2000 and 2001 needs correct Mopar O-2 sensors. Voltage values so sensitive that a check-code lights. (Swap to our $399 MoPar Hi-perf ECU to defeat this!)
BurnR8
Redmond, WA
Sir JonB....will the ECU stop my trouble code for sure...I have not installed the one I bought from you but it is on the list....I have cleard the DTC a few times with software..but she keeps coming back on....does the new box "allow" for non EGR emissions? thanks BTW-just threw on the Eibach's you sent up....much better!!
Thanks,
Paul Fischer
Texas, USA
Just go to your local Dodge dealer and buy a set of the Neon sensors. They'll know what you want, you won't need a number. With all due respect to JonB, splicing the wires can set up a voltage impedence problem, it did on my GTS when I went to sidepipes.
Double D
