O2 C/E light solved
ACR Joe
Newtown, PA
Apex Smakebox solved light from rear O2. I have refrained from moving front O2 as described above as the c/e light has remained off. I am running a full Belanger system w/o cats. That may change to w/cats shortly.
Steve 00RT/10
Michigan
While by no means a Viper guru, it is my understanding that a misfire code MIL can be set regardless of 02 position. The computer monitors the actual firing of the cylinders separately from the 02s and will set a light if it detects what it considers a misfire problem ahead of a fire. I do realize that one of the purposes of the 02s is to correct the mixture prior to this condition occurring.
Steve
cs83
