oil cooler lines leaking
1fastviper
charleston,W.V.
i posted awhile back about my oil cooler lines leaking on my 03 vert.i wiped them off awhile back when i seen them leaking.about two months ago.i wanted to see exactly how bad they where leaking.so i checked them the other day and not one drop of oil had seeped through.what the heck.i bought this car last year and it only had only 11000 miles on it.and its a 03.so what im thinking is that it had to be sitting somewhere for a long period of time and the oil just sept through lines from sitting is this possible.
ViperGTS
>>> the oil just sept through lines from sitting is this possible<<<
Pictures?
No pressure sitting...high(er) pressure when driving!
Viper Wizard
South Salem, NY USA
Those connectors are not the best and I see a lot of them leaking! :mad:
Disconnect the lines are clean them good [Thrust starting fluid] and put some silicone/RTV on the male end were the O/rings go and then connect them. Let dry over night! That should do it? :cool:
