Quick disconnect help
MattInNC
Havelock, NC
While removing my fuel pump assembly from my 99 GTS, the quick disconnect fitting came apart on me. (the one that goes to the fuel pressure regulator)
Does anyone know the correct re-assembly order?
The green o-ring is still inside the female connector on the fuel line. So I am left with a yellow o-ring, a white spacer, a black spacer with a beveled edge and the blue two finger connector which goes on last.
Anyone? I attached a couple of pics as well...
Viper Wizard
South Salem, NY USA
Hi Matt,
I left you a phone message. For everyone else disconnecting/connecting fuel lines: These assemblies come apart frequently, so ALWAYS check the fuel line going back together!! Look into the female connector, green O/ring - white spacer - yellow O/ring - black spacer [the shoulder at one end goes towards the outside] and last the blue quick disconnect retainer, that holds the assemble together in the female connector. Hope this helps? :cool:
914-763-3136
Viper World
dave6666
Dude. You're a US Marine. You should be able to look at those parts and order them back together.
Please, next time...
GreatWhiteKAC
