Quick/Easy Question...
Hamrhead
eastern, Pa
Looks to me like each grill has 6 push-in pins to hold it in place.
Carefully remove them and the grill should fall out.
BTW, I need ONE of these push-in pins as one of my grills only has 5.:dunno:
Omaha NE.
The push pins are very hard to remove and will take a bit of force. Most or all of the pins will be worthless when you are done, just did mine.
P
paul tat
Fresno, CA
I actually like the look better without the grills. If I break all the pins, will I be able to order just pins from dodge?
