This hasn't been discussed in some time and I just talked to someone who didn't know about it so here is an old topic again.
Remove the front facia bolt that is underneath the coolant tank on the passenger side. If you don't know where it is, remove the rubber circle thing in front of the wheel, locate the plastic tank, locate the screw underneath that is inches from puncturing the bottom of the tank. Cut 1/3 off the top of the screw and smooth out the top, reinstall.
It is common for people to scrape the facia and push this screw into the coolant tank and find fluid all over the place. There are other reasons for having coolant in the same location but that is another thread.
