The stock viper has two breather systems, the valve cover vents and the PCV valve. The two are separate and not linked together. The Roe breather was to replace the PCV valve that I blocked off. I did not want to reduce the oem venting capacity. There is a negative to not pulling vacuum on the crankcase thru the PCV valve, you will contaminate the oil quicker, hence, another reason for not reducing the vent capacity.
I had a problem with both systems. I pulled the intake in December to port match it to the heads, it looked like someone had poured oil thru it. I also had a problem with hard/long left turns on the track, the oil from the valve covers would actually make the car stumble. This was partially due to the T&D rockers, they drastically increase the oil flow to the valve covers. I now have no crankcase gases or oil dumping back into the intake and I have the oem vent capacity.
