RT/10 Mopar Spoiler Installation Tips
ViperTony
Mine just lined up perfect with the rear quater lines....
Not this template. Symmetrically, it's fine but it's wider than the trunk lid so the RH/LH lines on the template that are supposed to line up with the edges of the trunk lid actually rests over the quarter panels (you can see this in the pic). The bolt hole pattern on the template doesn't line up with the bolts on the spoiler. It's as if the template is a 1/4" off scale on everything. But I worked around this.
Baz, did you follow the Mopar instruction sheet? The part I'm not clear on is how to align the template with the marks I made 13 3/4" from the top of the trunk lid corners. My question is: Do I align those marks with the edge of the paper template (as shown in the pic) or do I align those marks with the line on the template (B.). Instructions just state "align template with the mark"....ok. I'll give Tator and/or Vipair a call today to confirm.
VIPER BAZ UK
ENGLAND
Tony
Just checked and my template is plastic not paper...
The only paper templates i got were for the under side of the trunk ...
ATLVPR
