settings for lowered viper (94)
VIPER BAZ UK
ENGLAND
car is lowered but do i use stock settings (did have a link to Mike Adams settings but i lost it)
V
VIPER BAZ UK
ENGLAND
Any body help
Viper sits great but need the settings for a lowered viper using eibach springs garage only has stock settings are they the same ..Only gets road use ???
Many Thanks
Baz
VPRVENM97
Silicon Valley, CA, USA
Is this what you were looking for?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Mike Adams:
Make sure the fuel tank is about 1/2 full this will allow a split between full and empty. The more negative camber you put in the car the less it tends to follow the road. My settings for street are
Front camber -.25 to -.50
front caster 6.00
toe 0 to .05" (keep positive to compensate for negative camber wear)
rear camber -.25 to -.50
rear caster to spec (if he has a caster tool ) if not tell him when adjusting camber make sure the adjusts front an rear camber bolts in control are same amount you can visually see the lower ball joint move forward or back
rear toe 0.00 to .05" same reasons as front
<HR></BLOCKQUOTE>
