Something leaking
paul
columbia,SC,USA
I noticed the other day that inside the rear wheel there is a light brown color that has dried on the garage floor. Does anyone know what this is. It appears to leak right under the battery compartment. I hope this is not bad, but the car seems to run fine and all the fluids seem at level. Thanks.
luc
Paso Robles CA
Could be your battery leaking acid.
Brown color is either water mixed with dirt or acid mixed with rust.
You should remove the panel and check it.
Luc.00GTS
cs83
