Paxton wheel hop
efnfast
Canada
If I'm in 2nd or 3rd around 3,000 RPM (paxton, built engine, dual walbros, 85lb injectors, oversized intercooler, exhaust), if I roll on the throttle such that I'm only at WOT around 4,500 rpm the car drives fine. But if I floor it, I get an immediate violent bucking and have to immediately lift because it feels like something is going to break.
My car came with a VEC2 and initially I had nothing but problems with it - I would get random surging at speed and at WOT the car felt like it was barely making any more power than stock. I got rid of the VEC2 and did a custom dyno tuned 3 bar MAP tune on the stock ECU. That cleared up all the drivability issues and made the car feel like a 700RWhp car, but that's also when the bucking issue started (although a dozen dyno pulls were fine and the fuel curve looks clean, I only noticed the bucking the first time I hit it on the street)
In my higher hp cars when I lose traction at speed (e.g., at 60mph) I can feel the rear wheels spinning but the car itself itself feels smooth. This here feels like something like the differential is on the verge of breaking if I stay in it. However, all my other cars everything is solid mounted and no bushings on the suspensions (just rod ends), so I'm wondering if I'm experiencing wheel hop because that's the area of the curve where the Paxton immediately spikes up?
Old School
North Alabama
My Gen3 (no Paxton) had wheel hop until I installed poly bushings in the suspension, lower shock mounts, diff mounts, and motor mounts.
E
efnfast
Canada
I also have a modified (heads, cam, intake ... all n/a stuff, no f/i stuff) 2008 and 2017 and neither of them wheel hop - if I stab the throttle it just goes (albeit with some wiggling).
Part of me wonders if this is something mechanical like wheel hop because of how hard the paxton hits in that range, and part of me wonders if maybe it's something related to the tune still (although it looks fine of the dyno ... but of course on the dyno you're starting a run in a higher gear and lower RPM, this seems specific to if I try to go WOT around 3k rpm)
Try adding a little more rear toe-in. Also try dropping the rear pressures a couple of psi. What tires are you running, and how old are they?
E
efnfast
Canada
pilot sports; 345/19; around 33psi; less than 1 year old
but if it were a tire issue wouldn't I just lose traction and smoke the tires?
i would describe this as a very sharp bucking, like the back-end is jerking back and forth violently and going to snap
I've never experienced wheel hop before so that's the only thing that comes to mind
Dragsters call it tire shake. There can be a number of contributing factors, but until you get it figured out, start lowering air pressures and trying NOT to keep wheel-hopping it. Something is going to break and it won't be pretty.
E
efnfast
Canada
motor and trans mounts new/good?
yes, replaced them 2yrs ago w/ Ipsco parts
agreed; I don't drive my cars hard so it's not much of an issue per say, moreover a 'i wonder if others experience this and what their solution was'.
I'll try lowering tire pressure - only reason I set it there is with 18 cars I try to standardize as much as possible so I don't have to remember specific settings for anything, haha. And actually, thinking about it, on the dyno I think we had to drop them to around low-20 psi range because of traction issues.
EastCoastSRT10
Maryland
You can get wheel hop if your rear alignment is jacked up.
I don’t know specifically why but my gen 3 with just a tune and catback had wheel hop after my last shop jacked up my rear alignment.
Make sure you have positive caster in the rear and shoot for about 0.25 degrees toe IN. For caster aim for about +1 degree.
That should help as my wheel hop went away entirely once I fixed the alignment.
meandmyGT2
