Spark Plugs for SRT-10?
Viper X
Hi Group,
Who is running what spark plug and what do you recommend? I have an 04 SRT-10 and headers are here (install planned for next week) but I'll bet the plugs that work in the Gen I's and II's will work well in my 04. I looked for threads and found a reference to Champions (stock) and Denso Iridiums, but not much more detail. I researched and then switched to Densos in my Corvette and they worked really well. Opinions / Input Please?
FlyBryViper
Dallas-Republic of Texas
Autolite Double Platinum = #APP 985
Single = # AP 985
Bosch +4 electrode/Platinum = #4428
+2 = #4308
Champion = crap!
Autolite Platinums resulted in what seems like a faster hot start, and run great! Have not tried any of the others yet!
Skip White
Kingsport TN
Viper X you've asked the $64,000.00 question. My advice is to do a search on Google and educate your self on this, not to mention the advice this site has to offer on the subject.
I've heard that Platinum can produce less of a spark kernel. This I've heard from several. I think there strong point is in longjevity. Plug gaps are also very important. If your keeping your engine stock for the most part, little to worry about. Some people have had improved results with different style plugs. My Uncle builds the most advanced circle track motors out there and does not use Platinum tip plugs. I'm not saying I know for sure, but the stock plug is not bad on a stock engine.
Skip White
Viper X
Viper X
Thanks Skip and FlyBry,
Engine is not stock and will have cam and heads plus soon. Interesting how so few Viper owners have responded to this simple question. Come on guys, put your two cents in.
Dan
Stu Man
Would you recommend the same spark plugs (Autolite Dougle Platinum) for a '97 GTS Viper? My car mostly stock except for:
Smooth Tubes
1/4" bigger exhaust tubes from manifold to tips
19" HRE's
High Flow CATs
High Flow Headers
Thanks in advance
Viper X
Viper X
Paxton coming next week. Any advice on spark plugs for it?
tomg
Fl
ngk 6097'S. Car idles much smoother. 1 heat range colder than stock. .030 gap.
Vipermann
Texas
Denso IRIDIUM ... the best plug out there ... period. Had them in an Acura, felt the gain. Had them in my Vette, felt the gain. Never felt squat from any other plug change. Will be putting them in my SRT soon ... the Vette websites have all sorts of graphs and charts that prove this also -- I can just say, 'they work'
STUGOTS
NY/CT
I was looking into using them im my viper as well but from what I hear the Champs work best on vipers.
Daniel Cragin/DC Performance Inc
Los Angeles, Ca
NGK 4291 is a good replacement plug for blower applications.
Bosch F4CS works great for real high boost (12-15PSI) but will set misfire code at idle sometimes on 2001-2005 models.
Iridium plugs also work great but probably not worth the expense.
Racer Robbie
Guilford, CT-USA
as far as denso i tried ik16, 5303 *** they did not work well. Denso sent me some ik20, 5304 to try. What denso number has nanyone found to really work in a stock srt-10 with k & n box and different mufflers.
please email me at [email protected]
xeng yang
